RE: Ceramic Igniter and ECU battery
gruntled:
If you have a 7.4 2s2p LiPo battery of 30C and at least 3000Mah, please fully charge and try this combination. Seems to work very well.
Igniter install: use the supplied washer, then thread into the turbine. Place ground strap under one of the Mounting strap lugs. Works great.
Let us know if you have further issue.
Regards,
Eric
