RE: Inverted Engine Performance Question
You don't tune an engine for smoke, you tune an engine correctly, a few hundred rpm under it's max you re getting with the prop being used. If you want to see more smoke then add some more oil to your fuel. Fuels that have no Castor smoke very little. Fuel tank set up can effect an engine when the plane is inverted. The engine doesn't know it is mounted upside down but you set up has to be correct.
