RCU Forums - View Single Post - ST2300 Testing and Experimenting
Old 04-22-2011 | 09:29 PM
  #853
jaka
Default RE: ST2300 Testing and Experimenting
Hi!
If you have the engine cylinder at 90 degrees and the carb high speed needle pointing down...you have the carb mounted the wrong way!
It doesn't matter really ,but why have it in that arkward position!???
Turn the carb around 180degrees and you'll have the high speed needle pointing up and the R/C throttle arm pointing down, the way it should be.
