RCU Forums - View Single Post - OS engine owners
Old 04-23-2011 | 11:13 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: OS engine owners
ORIGINAL: marshrabbitt
Btw this is on a airboat...figured you plane guys knew these engines inside and out.
Vital and Critical Question Here:
Is this boat configured as a pusher or tractor?
If the boat is a pusher And you run the engine static four or five minutes you are going to over heat it regardless.
Break the engine in on a test stand using a conventional tractor prop.
John
