RCU Forums - View Single Post - finding your radios range
Old 04-23-2011 | 04:00 PM
scooterinvegas's Avatar
scooterinvegas
Default RE: finding your radios range
Im going to guess 12,387 ft, 11 in.
The range is farther than you can see the plane. The is in a wide open space with no obstructions of any kind. The lower your plane is to the ground, the less range you will have. That is, a plane 200' high will have a longer range than a plane that is 20' high from the ground.
I know 1st hand the a 2.4 DX7 has a range of a little over 2 miles. Again, with NO obstructions and over 200' high.
