RCU Forums - View Single Post - Simjet 3000 problem on XL
Old 04-24-2011 | 12:55 AM
Vinceyboy's Avatar
Vinceyboy
Default RE: Simjet 3000 problem on XL
Hi, update to my Simjet 3000 problem, I have tried the suggestion made without any success, also scrolled through the Data Terminal, all-in-all, the starter does not engage, and so comes up with "Start bad" we have plugged a battery into the starter lead and it spins up perfectly, so it seems that the ECU is not powering up the starter.
I feel that the ECU may have become corrupted or damaged when the input terminals were wrongly plugged in, so I am sending the ECU back to Gaspar to get it checked out, I'll let you know the outcome.
Cheers,
Vince.
