RCU Forums - View Single Post - No string to pull servo wire through wing!
Old 04-24-2011 | 03:21 AM
jbdismukes
Default RE: No string to pull servo wire through wing!
Obviously, this is not a unique problem. In <u>some</u> instances, I use a length if thin florists' wire. With a gentle touch, you can feel any obstruction and feel your way through the rib openings. The wire is then used to pull the servo lead.
Jack
