RCU Forums - View Single Post - Viper Jet 2M Pointers/ tips.
Old 04-24-2011 | 04:37 AM
  #324
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: Viper Jet 2M Pointers/ tips.
The motor mounts did not have material where it was needed, so I cut some 1/4" plywood and hysoled it in place, when dry I painted to match the rest of the interior.
I used a paper 1:1 drawing of my rabbit (see attachment) as it was mounted in my Flash at the time I was fitting up the Viper. I had to remove material from the inside center of the air inlet box to move the Turbine as far forward as my pipe length would allow. I included a full size pdf template for the motor mount add on pieces.
ID:	1598225   Click image for larger version
ID:	1598226   Click image for larger version
ID:	1598227   Click image for larger version
ID:	1598228   Click image for larger version
ID:	1598229   Click image for larger version
File Type: pdf
File Type: pdf
