RCU Forums - View Single Post - Lightning Build
Old 04-24-2011 | 05:24 AM
  #135
Viper Driver's Avatar
Viper Driver
Default RE: Lightning Build
I use 3/8" dowel hard points for the control horns. To cut the holes, I use a sharpened piece of brass tube in my drill press. Once the holes are cut the dowels are epoxied in. After that cures, I use the Dremel router attachment, with the bit set flush, to shave off the excess dowel. Once that is complete, I use the drill press to drill the hole in the hard point for the control horn.
It is getting close to time to put away the 60 grit and get this thing fine sanded, glassed and painted/monokoted!
ID:	1598242   Click image for larger version
ID:	1598243   Click image for larger version
ID:	1598244   Click image for larger version
