RCU Forums - View Single Post - No string to pull servo wire through wing!
Old 04-24-2011 | 05:35 AM
padlock
Default RE: No string to pull servo wire through wing!
Take the outside tube from some pushrod. Feed some string thru it, tape the string lightly at the end leaveing a loop and snake it into your wing. Take some tweezers and when you see the string loop thru the hole in the center of the wing. Grab it
padlock
