RCU Forums - View Single Post - Engine getting too hot
Old 04-24-2011 | 08:38 AM
jester_s1
Moderator
Default RE: Engine getting too hot
If you are losing power in the vertical you are too lean. That would also contribute to the heat. To help with cooling, you may need to put some baffles in your cowl to direct the airflow over the cooling fins of the engine.
