RCU Forums - View Single Post - bme 102
Thread: bme 102
Old 08-12-2003 | 05:24 PM
Steve's Avatar
Steve
My Feedback: (54)
Default bme 102
Power should be the same. The older 102 and the newer 102 use the same pistons, rods, and heads. The only difference in the motors is weight, looks, and a different reed valve block. The newer reed valve block may give it just a tad bit more power. I need more weight up front so the older style works good for me. Though I do have the newer version also. If you get an Evo. model, just make sure you have stainless bolts in the heads. Not the aluminum ones some models were shipped with.
Steve
