RCU Forums - View Single Post - Tow Cables
Thread: Tow Cables
Old 04-24-2011 | 10:47 AM
hdbeast's Avatar
hdbeast
Default RE: Tow Cables
ORIGINAL: starskey
Hi
Does any one make there own tow cables?
How do they make them?
Jon
Hi Jon
I make my own cables using picture cable or any small cable I can find from the hardware store, I make the ends using copper or aluminum (aluminum is easier) tubing cut in half with a dremel tool. I lay the cable in the channel then bend the loop and tighten it up around the cable with flat nose pliers, a larger piece of tubing to slide the ends of the cable into and glue with JB weld or epoxy
Gary
ID:	1598379   Click image for larger version
ID:	1598380   Click image for larger version
ID:	1598381   Click image for larger version
ID:	1598382   Click image for larger version
ID:	1598383   Click image for larger version
ID:	1598384   Click image for larger version
