RCU Forums - View Single Post - What allows Kingtech to use diesel where others say you can't?
Old 04-24-2011 | 01:35 PM
  #131
Delta Mike
My Feedback: (18)
Default RE: What allows Kingtech to use diesel where others say you can't?
Barry explain how you can get a increase in Thrust using diesel fuel.. Am I missing something here? Doesn't the RPM of the turbine determine thrust? If your ECU settings stay the same for the MAX RPM, then where does the increase in trust come from when using diesel fuel over JET A?
Dennis
