RE: Ziroli 124
My new issue to deal with. Since the wheels are so big there isn't room to put a faux rib in place far enough away from the side of the last rib of the center section so I could use off set hinges. I am experimenting with using my bench sander to sand some large robart hinges down to half thickness and glueing them to balsa gear doors. It looks like it will work but I would rather use metal off set hinges. I really don't dare to cut into the first rib of the outer wing panels for them to work. Any ideas anyone? Any suggestions or help will be appreciated here!!!
