RE: Spray Bar alignment
A true variable venturi is ideal because it maintains fuel draw at part throttle. Our rotating barrel carbs lose fuel draw at part throttle, the venturi effect is lost as the barrel closes. You should be changing the fuel metering rather than wasting your time with the spraybar. Its easy to do with a Supertigre style carb by grinding the cam slot. Its very difficult to modify a fuel metering slot because of its small size.
