ORIGINAL: gruntled
Thank you Mike that is helpful. When it failed to ground, what error or message did it generate?
Using the HDT, the Glow Test would not display and the start sequence would not proceed. I tried mounting the ground wire several ways to the turbine mount (i.e. between the bolt head and washer, between the washer and strap, etc.) and could never get it to work. I'm sure that I had something goofed up, so I just went back to what I had been using before. The installation order that I use at the igniter is.....washer, ground wire, then igniter.
