RCU Forums - View Single Post - adjusting control surface throws
Old 04-25-2011 | 02:26 PM
goirish's Avatar
goirish
Default RE: adjusting control surface throws
Are you using dual servos for the ailerons? If you go to the inner most hole on the servo and the outer most hole on the control horn that will give you the least amount of throw. You may have to go with a smaller servo arm.
