RCU Forums - View Single Post - Ignition Battery Voltage Question
Old 04-25-2011 | 05:15 PM
  #34
Truckracer
My Feedback: (19)
Default RE: Ignition Battery Voltage Question
ORIGINAL: captinjohn
Well I read all the replies so far. I never really noticed that my Sirrus Pro charger did any better at all than the common ordinary charger you get with your TX system. in fact I use it only as a field charger for about 10 min when I do use it. So I will do like Tom & others say...just use a standard low rate charger for the Eneloop battery packs. I think the low rate may be best....a gut feeling. Best Regards, Capt,n
When used on correct sized batteries, the Sirrus is a very good charger. Also, I would certainly use it for a quick top off charge at the field. Just keep track of the time it is on and don't walk away and forget it. Its only real fault is that there are better chargers available today. All their info, specs and manuals are available for viewing at their website.
