RE: Engine getting too hot
When you close the throttle barrel you will also close of the fuel supply and the engine stops as it can not run on air alone. It can take a while to empty the crankcase from fuel but then it stops.
A stripped carb screw will give and engine that runs too lean, so that should be the first thing to fix before looking at other things.
