RE: Antenna Length
Thanks for the reply. Fuselage,cowl, and wing are all fiberglass. The reason I asked was that the prior owner of the boat had a FM system in it and had about 3 feet of antenna wire flopping in the breeze.
Another question - knowing that there is a lot of variables, what could be a range of the range of the transmitter? (I plan on doing a range check on terra firma before it goes in the water). Also the rudder is (I think this the proper term) glitching with no input from the transmitter - normal? a servo problem?
