RE: Volcano S30
first off im gonna tell you how to fix the break problem.. if the motor is stullin out when you pull the break screw in the idel screw in and then test your breaks to see if the throttle arm moves.. now most ppl will tell you that there should be a 1mm gap in the carb and this is true so make sure you look at that before you start it up so it doesnt take off.. On your breaks all you should have to do is move or tighten the the linkage towards the servo arm.. For the motor, mind you its been awhile sense ive had my redcats, but i think the hsn should be close to 2 1/4 turns out and the lsn was 3/4 of a turn in from flush.... hope that helps
