RCU Forums - View Single Post - Zip Ties in Gas tank
Old 04-27-2011 | 02:54 AM
CGRetired's Avatar
CGRetired
Default RE: Zip Ties in Gas tank
Hold on here.. Since this is a beginners forum, and a lot of beginners refer to our fuel as "gas", it is NOT gasoline, it's alcohol (ethanol and nitro-methane plus a blend of oils). If the OP IS talking about gasoline... petrol... petroleum based fuels, then ok.
I am not quite sure how the plastic would do in a fuel (ethanol) tank, if it would decompose it or not, but I doubt it. For Gasoline, however, it does strange things to certain materials, so I would be very careful using plastic zip-ties in any fuel tank.
A twisted copper wire works, as does a good tight fitting glow fuel tubing around the barbed clunk feed tube without anything else. There are differences in tubing material for gasoline and glow fuel (ethanol based fuels).
CGr.
