RCU Forums - View Single Post - How to solder like a Pro - on a budget
Old 04-27-2011 | 07:54 AM
dragnse7en
Banned
Default RE: How to solder like a Pro - on a budget
That would be a pretty tight fit. The diameter of that wire is about 3.26mm, and the terminal ends are 4mm. I would split the strands in half and then sprial them up again, and solder them to both sides of each terminal. Strip the insulation ends a bit more so that the strands can seperate and bend around in a better fork-like shape.
