I been experimenting with mounting of the batteries as far up front as possible, Skymaster does give some room in the front; however it allows the batteries to press against the fiberglass and will cause distortions over time on the outside skin.
So I designed a battery carrier, I need to add a holding mechanism for the tray, and some slots for the battery hold down straps... other than that it should work
