ORIGINAL: johnvan29
I have a DX8 currently, will this radio be able to work I you use Y harnesses and such for servos even though I have more than 8 servos? Is it better to just bite the bullet and get like a 12X or can I be just fine with what I have now?
If you have a DX8, just use it and don't worry until you get stuck.
If you optimize your mechanical set up, use some matchboxes and reverse servos, I bet you can do 99.9% of available jets today on 7 to 8 channels
You can do:
1 Throttle
1 Aileron (Y, Matchbox, good geometry)
1 Elev (Y, Matchbox, reverse servo)
1 Rudder/steering (Y, Matchbox)
1 Flap (Y, Matchbox, reverse servo)
1 Retract
1 Brakes
1 Gyro
That's 8 Channels there...
if you need more, you can get creative
You can free up the brakes by mixing with elevator
or if you need airbrakes you can combine with flaps or brakes using a channel expander
You might not need a Gyro, or you might have a fixed rate one and also free a channel
My F100 was set up on 9 channels and it has flaps, slats, airbrakes, proportional brakes and a parachute!!!
So net net, if you have it, don't worry. It is doable.
But, it is soooo much easier with more channels
Hope this helps
