ORIGINAL: noginblue
Ah sorry didnt explain properly as brain wasnt working, earlier in the post someone was on about the st g90 which is what i have and have already converted it to gas but want to lower the oil content. Not highjacking thread but seems some people on this thread know more about it then me
16:1 gas/oil when running the bushed connecting rod
You will need to search for the needle bearing the others are using and select the proper size drill rod for the crank pin to run less oil.
