ORIGINAL: box car
I am building a twin with 2 ST G90 on it. I would like to put ignition and a CM6 plug on them and still run glow fuel. Will this work? The reason I want to do this is I want to mount tacks in the wing behind the engines.
Ken
Should run fine but there will be a problem with the reach on the CM-6 plug. You will need to shim the plug up with two washers under the threads
