RCU Forums - View Single Post - Tsunami Build Thread
Old 04-27-2011 | 08:23 PM
  #296
doxilia's Avatar
doxilia
Default RE: Tsunami Build Thread
Brian,
Yea, the LightFlight link breaks but I found it from the home page.
Here are the specs:
SUPPO 2212-06
• 47g Outrunner
• Kv: 2200, Rm: 0.045, io: 1.4A, Poles: 14
• Max watts: 240, Max amps: 28A for 60sec
• Shaft is 3.17mm
• Dimensions: 28mm x 30mm
So not a 22 mm can but a 28 mm - much better. Phil, is this what your motor is like? Will you be doing fixed gear, retracts or gearless?
They might not have quite as much muscle as the 1460 kV Dualsky's but they should do just fine on the little Tsunami. After all, 240W max is about 120W/lb which is just fine on a model this size. I want to put in retracts so I'll take the 300W. I just need some small electric retracts. The E-Flite's are too big but I think there are some smaller options now.
David.
