ORIGINAL: vquick
you have to create the conditions as single not as groop
You need to change the AFR for each control from Group (GRP) to Single (SGL) in each of your conditions. In the function screen you should also change the trims to SEP for those that you want to be able to adjust individually in a condition. I keep aileron and rudder grouped and make elevator SEP on the trims.
Adjust the throw, expo and such in teh AFR screen of the MODEL menu. Leave the ATV in the Linkage menu the same. AFR adjusts the throws in each condition.
