ORIGINAL: d_bodary
Trying to get the E-Motion ready for it's first flights
I would like to set some flight conditions
Condition 1 Normal controls and throws
Condition 2 Decreased rudder same aileron and elevator as condition 1
Condition 3 Decreased rudder increased aileron and elevator as condition 1
Now i changed the transmitter to switch to condition 1,2 and 3
using one of the three position switches.
So when i change the switch it does go condition 1,2 and 3
I saved my normal flight controls and also put them on condition 2 and 3
But my problem is everytime i change the control endpoints. then flip the switch it affects all three conditions.
Obviously i am doing it wrong, Just not sure what i am doing wrong.
you can accomplish the same thing just using the dual rates....
Position 1: High Rate Rudder, Low rate Elev & Ail
Position 2: Low Rate Rudder, Low rate Elev & Ail
Position 3: Low rate Rudder, High Rate Elev & Ail
Though there is less overall flexibility using the rates verses using the conditions...
