RCU Forums - View Single Post - Engine getting too hot
Old 04-29-2011 | 06:27 AM
  #46
Mr Cox's Avatar
Mr Cox
Default RE: Engine getting too hot
ORIGINAL: ameyam
I am also hunting around for a tach and infrared gauge.
The infrared gauge is not needed, it doesn't really tell you anything, the engine will tell you when it gets too hot by dropping in rpm. The tach is useful though and can tell you more accurately if the engine can hold the rpm or not. You should also have a clear rpm response when you change the main needle setting.
