RE: Struggling with single rotor basics V2
Scott, I am chasing issues with the set up. I get an aileron bobble on hard pitch pumps every once in a while. I am going to change the tape to 3M and see if that helps. Others are flying the same setup, so I know it will work.
I got the Beam E-4 flying and flying well too. Flips so fast and axial. Really liking it.
The Rave did not come out as well. I replaced the cyclic servos with JR DS85s which are fine but the JR 3500g I put on the tail had a stripped gear in it so I ended up putting a 3400g on instead. That servo, the Spartan DS760 or the way I have it set up just do not seem to be jiving. I get bounce stops in one direction and slide stops in the other. I ordered a gear set for the 3500g and will put that on when it comes in.
I got side tracked with the Rustler so I did not get the Outrage G5 up and running. Plus I was missing the satellite RX adapter till Alex hooked me up the other day.
My 450 Pro still flies like a champ.
I did not fly my Furion but it is always awesome.
I am waiting on servo gears for my HK450B after that last crash when the swash ball screw fell out. All the other damage is repaired. Not a bad crash at all actually.
The HK450A got flown last weekend at the dome and is flying excellent as usual. I even did a flip or two and tested inverted for a moment. Glad to have it back in the fleet.
The Align 450S GF should fly just fine although I just can't remember the last time I flew it.
The Copter X should fly just fine but it is just like any of the other Align / clones I have.
The EXI needs a tail gyro and flybared head. It did not fly well with the Gaui GU365 or the BeastX. I am sure the issue with the Beast was the servos I chose. They just were not up to the task.
The Align 450XL needs an MD500 fuse.... and all electronics. LOL. I think that is all that heli is good for.
