RE: Hangar 9 pt 19 36
rayzer 13,
Your opening statement implies that you have flown CL before. With that in mind, I would suggest you rebuild it and fully check-out EVERYTHING to do with balance and alignment before launching again.
Did you pull test your lines and check the controls for equal up and down...and that up was up and down was down? I think most of us have connected the lines incorrectly to the leadouts at one time or another.
Someone recently wrote that a nose-heavy plane flys sluggish while a tail-heavy plane flys once.
You have been given lots of good advice on this thread, something should help. Good luck with the rebuild, and welcome back to CL.
George
