RE: GP Super Stearman
Steve, due to the offset built into the firewall, the cowl will not sit straight if the crank shaft is centered. I try to get the lines on the sides as close as possible, and the crankshaft as close to center as I can. Usually this results in one side being in perfect alignment, the other is a little off.
Hope this helps
