RE: Pheonix Extra 330S 60-90 Size
If Nolefan1961 is right about the fuel tank issue being to far forward, (and I think he is) then there would be room forward of the tank about two inches wide (or more if you decide to try this) so that you could mount a small servo tray right behind the firewall for your throttle and choke servo's. It is what I was thinking of doing with my rcgf 15 should I decide to use it. This way the rod lengths are short and no issues with the fuel tank. Since you are adding weight with the servos and tray then you can move the tank even a little farther back. In mine there seems to be plenty of room to do this. Just need skinny hands to mount.???
What do you think, good idea or bad?
