RE: Best glue type
Bryris, I would use epoxy. It will hold better than the would glue. With it being electric you can replace the would with the same type or slightly stronger/thicker (but you would have to decide that depending on how powerful your setup is) and even use CA. However, I personally would use the 30 minute epoxy to hold better. Hope this helps. good luck.
Joe
