ORIGINAL: vasek
Hi,
i need some advice on how to make a tunnel hole for inserting a 1.5 mm carbon rod in a sheeted foamcore stab.
Just heating up a metal rod with open flame does not appear to be a great solution, as the wire would cool quickly and i would have to insert the wire several times making the hole larger at the beginning...
is there another simple way to do it without making/ buying sophisticated and expensive hardware?
Thanks for any tips!
I know a guy who cuts slots for half-length ribs that contain holes for the tube. Then a slot for the tube, then (with the tube in place) epoxies the ribs into the foam. When cured, he fills in around the tube.
Might work for you. Good luck,
Dave Olson
