RE: Setup Tips for your MCPX
Hi, I tried the above settings on my DX6i, and the new mCPX I have acts really weird, I dont know if its the radio settings or the bird itself.
I thought the cyclic should return to center with the stick under power, and this one doesn't, at idle it does. Instead when power is applied, if you apply left forward, right, or back cyclic, it stays there when you return to center. I have to move the stick to the opposite side to bring it back. I dont think this is normal. I also dont have throttle unless I press the throttle cut button on the transmitter, so I think I have something screwed up, not sure what though. Is this all radio, or is it bird?
