RCU Forums - View Single Post - St g90 gas conversion tuning issues
Old 05-03-2011 | 02:49 PM
av8tor1977's Avatar
av8tor1977
Default RE: St g90 gas conversion tuning issues
If tuning, especially richening up the high speed needle doesn't help, check the carb screen and then the fuel pump diaphram. I have seen the pump diaphrams get distended and then they won't pump enough fuel at high throttle. Also verify that your pulse line to the fuel pump is in good condition with no kinks nor air leaks. Ideally, that should be a somewhat stiff line, and as short as possible.
(All this is assuming you have no air leaks whatsoever in the fuel supply lines.)
Also, do you have a filter in the fuel tank? Could it be partially clogged?
AV8TOR
