RCU Forums - View Single Post - ST2300 Testing and Experimenting
Old 05-03-2011 | 08:31 PM
  #859
vasek's Avatar
vasek
Default RE: ST2300 Testing and Experimenting
ORIGINAL: Roary m
Thank you much. I knew better than to post that about 2 minutes after I had, considering where I was sitting and what I was doing, duh.
[&o] ok i'm not getting this one...
BTW to have the same pressure as the original muffler, it is recommended to either block one of the two exhausts on the aftermarket inverted pitts, or [close] partially shut both exhaust (by putting the exhaust in a wice). Should work well.
