RCU Forums - View Single Post - Need trimming help...
Old 04-29-2002 | 12:02 PM
RickP's Avatar
RickP
Default The trick
Hello,
To avoid the conflict you are talking about I think it's important to do the trim tests in order. Specifically work on the inverted flight (move the CG back) characteristics before considering the knife edge pulling. It's possible that the pulling to the belly is the wing incidence also, but I think if you follow the charts in a stepwise fashion you will have better luck. Hope this helps.
Rick
