RCU Forums - View Single Post - CMP EP Katana SR
Old 05-04-2011 | 10:46 AM
stick man
Default RE: CMP EP Katana SR
Yeah I was wondering about the stock prop as I have a bunch of 5S 3300mah that i'd like to use on this plane. But then at 1.1lbs pre batt, I'm a bit worried about the weight of the 5S. ???
If the weight isnt too much then I'll stick with the stock 13x4 with the 5S, and maybe put a larger ESC in it, as recommended.
Also, I'm not exactly clear on what triangle stock is.
As far as the maiden is concerened, I'm not too worried because I've got many flights on my 72" Cub and a couple on my Cessna 182 now. I also have many hours on my rc helis so I think I'll be ok with the Katana, unless theres something weird about the flight characteristics that would throw me way off. ???
Thanks for your input!<br type="_moz" />
