ORIGINAL: energyman
Joe M.
If you don't mind, where did you get the Jett muffler extension? I mounted my engine this evening and made the same discovery.
Also, has anyone experienced excessive right thrust in their firewall? Thanks.
Energyman
Muffler extension ? Would you believe I can't remember the brand. My local hobby shop carries a lot of exhaust parts, so I dug through quite a few until I found one that fit. I believe it's a Dubro ???
Excessive right thrust ? What are all of you guys considering is excessive ? I spotted the right-thrust when assembling mine, so I dragged out the protractor and from what I remember, mine had 1.5 degrees offset to the right. I didn't consider 1.5 degrees to be excessive.
Joe M.
