RCU Forums - View Single Post - Mick Reeves Hunter
Old 05-05-2011 | 02:10 PM
  #77
dabevan's Avatar
dabevan
Default RE: Mick Reeves Hunter
What do people think of this pipe? It is supplied with the kit, but as you can see it is single walled. It is spot welded at the seem and when in the fuz has quite a lot of clearance from the sides of the fuz.
...note it doesnt have a funnel at the turbine end.
Should I bite the bullet and order a custom made double walled pipe, or is a dual walled pipe no less likely to fail?
ID:	1604737   Click image for larger version
ID:	1604738   Click image for larger version
ID:	1604739   Click image for larger version
ID:	1604740   Click image for larger version
