Dear Lord mate noooooooooooo! You keep saying what a good looking jet this is and then do that! Sacrilege
Can't you mount the servos inside the fuse so that just the output shaft/linkage is visible externally? Beats having those unsightly lumps of plastic stuck outside the model?? Might be a bit fiddly but you probably have enough access to do it?
Smaller servos would look better if you couldn't? Or is there any way you could side mount servos in the stab? Check out the Voltz (or Volz) servos.
M
