RCU Forums - View Single Post - CMP EP Katana SR
Old 05-06-2011 | 09:22 AM
opjose's Avatar
opjose
Default RE: CMP EP Katana SR
ORIGINAL: stick man
I got my new Katana today, yay! I'm setting her up now and so far it seems like a good little plane.
I have a question though- how do I wire the dual elev servos on my dx7/ar7000? does the second elev servo go to aux, gear or what? Or could I use an AR500 and use a Y harness on elev?
If you use a standard Y cables the servos will then travel in opposite directions... to fix this you could set up opposite horn linkages.
Or you could set up the linkages identically and use a programmable mix on your TX, or a servo reverser.
