ORIGINAL: golfandcards
The pinion is a 15 tooth. Which is stock. Same with the spur gear. It's stock. Ithink its a 48 tooth. Another thing to take into consideration is that the race is tomorrow morning. I wont have any time to practice with the new pinion in. Think I should just keep it the same until after the race? Then practice with the 14 or 13 tooth? What do you think?
agreed, just watch the motor temps or you can change the punch and timing settings on the ESC with the usb prgmr and keep running the 15t.
