RE: Replacing Piston Ring..
If you go into the glow engine forum and then into the OS support you can ask Bill Baxter for a correct answer. I run a tank through the engine after a new ring just to get it seating then fly the plane. Just because that's what I do doesn't make it the correct way. Bill can give you a truly correct answer.
