RE: help on power box champion rrs
These are the fs versions I assume they are by standard in normal ?.
I just tried different servos connected to the channel for steering, futaba 9451,and JR8411, hitec 649, same jitter but a mini futaba no issue. The problem also goes if I put the steering on a matched channel from the PB i.e. rudder, and leave the gear and lighting direct on receiver. Concern is it seems to work for other people, but then a few have experienced similar jitters and used only signal wire in rec. Madness........... with 1 receiver and no power box it is fine
